Flir ROS Driver
_images/flir.webp
Flir ROS Driver Parameters
It is necessary to setup the ROS parameters to enable communication between the camera Driver and ROS.
Flir ROS Parameters
ROS Parameter
api_file_path
Path to the REST api definition file.
camera_api_key
Every camera needs to authenticate the user data and requests.
camera_ip
IP address of the camera.
ir_format
Smart cameras provide data in different formats (e.g. avc, mpeg4, mjpg)
is_rgb_required
True if RGB image from the camera is required.
visual_format
is_http
If the communication is http or https.
overlay
Show/Hide camera overlay.
verbose
If true redirects API requests and json data to standard output.
Flir ROS Driver
  • Launch the ROS Driver
roslaunch flir_smart_camera_driver driver.launch
Flir Published Topics
Flir ROS Published Topic
Topic name
Type
alarms/active
flir_msgs/ActiveAlarms
alarms/triggered
flir_msgs/TriggeredAlarms
stream/ir
sensors_msgs/Image
stream/rgb
sensors_msgs/Image
