Pre-requisites
Autostart
Linux System Services
The robot automatically starts certain ROS2 modules on system boot via Linux system services. These services are created and managed using the |robot_autostart| package. These services ensure that essential ROS2 nodes are up and running as soon as the robot powers on. These services are created during the initial setup and installation of the robot.
To check the status of a specific ROS2 module’s startup service, use the following command:
sudo service |robot|-<ros2 module name> status
An example of this would be:
sudo service |robot|-webserver status
Auto Start Service Status
The service status will be indicated by a colored marker:
  • The red marker in the service indicates that the startup job has failed.
  • Green marker indicates everything is working correctly.
  • Grey marker indicates that the service has not started yet.
If an error such as Unit <ros2 module name>.service could not be found. Then it means that there is no startup installed. In case of red or grey marker, you may restart the service via:
sudo service |robot|-<ros2 module name> restart
Additionally, if you want to stop a specific ROS2 module, you can stop its service using the following command:
sudo service |robot|-<ros2 module name> stop
Custom Auto Start Service
If you want to modify the upstart job or add other ros launch files to it then it is recommended to add your changes to the main upstart file i.e. startup_installer.py located in the |robot_autostart| package. Once done, save the file and run the following command to update startup job. The other packages which are in auto start can be referenced for adding your own launch files.
ros2 run |robot_autostart| startup_installer.py
Coming Soon
Webserver
MBS Webserver
Test |robot_webserver| inside bold
This module should come pre-installed for heavy integration projects. It should be accessible directly at http://192.168.131.1:9000/ or the WiFi ip to which the robot is connected. The rovo_webserver can be configured via the config file in rovo_webserver ros2 package located in /opt/mybotshop/src/mybotshop/|robot_webserver|/config/robot_webserver.yaml
Login
The default login id is
  • Username: admin
  • Password: mybotshop
Dashboard
  • Enable the rovo ROS2 Services
  • Disable the rovo ROS2 Services
  • Record System rovo logs
System
  • View rovo external PC system status.
  • The battery only runs if the ROS2 drivers are enabled from the dashboard
Console
  • Movement of the rovo
  • Adapatable to new ros2 services
  • Record ROS2 bags
  • Access rovo external speaker if available
Telemetery
  • View rovo battery data
  • View rovo IMU data
  • View rovo Odometry data
Remote Desktop
  • On-board screen of the rovo computer
Navi Indoor
  • Disabled
Navi Outdoor
  • Disabled
LLM Interface
  • Disabled
Coming Soon
Teleoperation
Command Line Interface
Visualization
RViz2
To visualize the robot in RViz2, you can launch the RViz2 node with a pre-configured setup file. Use the following command:
ros2 launch |robot_viz| view_robot.launch.py
RViz2 should load with pre-configured settings. This is useful for visualizing sensor data, robot state, and other important information.
RViz2
Rigs
Coming Soon
Coming Soon
Manipulation
Coming Soon
Coming Soon
Sensors
Depth Cameras
Lidars
GPS
Auxiliary
Depth Cameras
Lidars
GPS
Auxiliary
Simulation
Gazebo
Isaac Sim
Gazebo
Isaac Sim
Packages
Robot Description
Twist Mux
EKF Localization
Robot Description
Twist Mux
EKF Localization
Debugging
Coming Soon
Coming Soon
Miscellanious
Coming Soon
Coming Soon
Installation
Installation Robot
Installation External
Installation Robot
