Manipulation
On platforms fitted with a manipulator, the webserver exposes an arm control interface for jogging joints, sending Cartesian goals, operating the gripper, and recording and replaying motion waypoints. The interface is only available when manipulation_enabled is set in the configuration.
Arm Control
The manipulation panel provides:
  • Per-joint jogging within the configured joint limits
  • Cartesian goals in the configured planning frame
  • Gripper open/close across the configured range
  • Forward kinematics and motion planning feedback
Joint groups and their controllers are described by the manipulation_joint_groups parameter, allowing multiple arms or arm-plus-gripper configurations on a single platform.
Waypoint Recording and Playback
Arm motions can be recorded as ordered waypoint sets and replayed later. Saved missions are stored as JSON files under manipulation/waypoints/.
  • Recorded missions are dispatched as a single trajectory frame list; the motion controller owns the trajectory timing.
  • Each frame carries its own timestamp, so the recorded timeline is preserved on playback.
  • Joint-mode waypoints may carry optional velocity and acceleration scaling fields (clamped to [0.0, 1.0]). These are captured from the UI speed slider when recording.
Each saved mission is automatically registered as a reusable skill (mission_<name>) that can be attached to navigation waypoints. See Skills and Missions for how missions combine with navigation.
Manipulation routes are registered only when manipulation_enabled: true. On platforms without an arm, this section does not apply and the panel is hidden.
