Clearpath Jackal
Attention
These tutorials assume that you are comfortable working with ROS2. We recommend starting with ROS2 tutorials if you are not familiar with ROS2 already.
The Jackal, a differential drive robot, is an indoor development platform created by Clearpath Robotics, a Canadian manufacturer. This documentation covers multiple ROS2 distributions to support various deployment scenarios.
Supported ROS2 Distributions:
ROS2 Foxy (Ubuntu 20.04) - Legacy support
ROS2 Humble (Ubuntu 22.04) - LTS release
ROS2 Jazzy (Ubuntu 24.04) - Latest release (Recommended)
The Jackal robot is designed to serve as a versatile platform for indoor research and development. Its robust construction and flexible configuration options make it suitable for a wide range of applications, from academic research to industrial automation.
Key Features:
Differential Drive: The Jackal’s differential drive system allows for precise control and maneuverability, making it ideal for navigating complex indoor environments.
Multi-ROS2 Support: Documentation includes support for Foxy, Humble, and Jazzy ROS2 distributions with synchronized tab navigation.
Ouster LiDAR Integration: Equipped with an Ouster LiDAR sensor, the Jackal offers high-resolution 3D mapping and obstacle detection, crucial for accurate navigation and environment perception.
ZED2i Stereo Camera: The addition of the ZED2i stereo camera enhances the Jackal’s vision capabilities, providing depth perception and visual SLAM (Simultaneous Localization and Mapping) functionalities.
Waypoint Navigation: The integrated waypoint navigation system allows the Jackal to autonomously navigate pre-defined paths, making it an excellent tool for autonomous indoor logistics and exploration.
Customization and Components:
The Jackal’s current configuration is tailored to maximize its functionality and adaptability for advanced robotics applications. The key components include:
Ouster LiDAR: Mounted on the Jackal, the Ouster LiDAR provides detailed 3D point clouds, essential for real-time mapping and navigation in dynamic environments.
ZED2i Stereo Camera: This stereo camera system offers high-definition video and depth sensing, enhancing the robot’s ability to perceive and interact with its surroundings.
Enhanced Computing Power: The onboard PC has been upgraded to support the computational demands of ROS2, LiDAR processing, and visual SLAM algorithms.
Custom Mounts and Enclosures: Specialized mounts and enclosures have been designed to securely integrate the Ouster LiDAR and ZED2i camera, ensuring optimal performance and durability.
