Installation
The package is designed to work on the Dingo-D. To install the package simply download it from the MBS MMP_Dingo-D github repo.
Give root permission to the installation script via
sudo chmod +x startup_installer.py
Run the script from the terminal via
./startup_installer.py
Provide the workspace name as
ros_wsand the directory as/home/administrator
In case the Dingo-D’s PC username is not administrator then manual changes will have to be made in the startup job.
Add a setup.bash file in
/etc/rosif its not there already.
cd
sudo touch nano /etc/ros/setup.bash
Edit the file and the configuration
source /home/administrator/ros_ws/devel/setup.bash
export ROBOT_SETUP=/etc/ros/setup.bash
export DINGO_OMNI=0
export DINGO_JOY_DEV=/dev/input/js0
Source and install the Dingo-D base driver via:
source /etc/ros/setup.bash
roscd mmp_bringup/scripts
./can-udp-bridge.sh
./install
