It is imperative to tune the Rovo according to your requirements before testing it.
Be sure to remain vigiliant when the robot is moving autonomously as it can cause
severe damage if uncontrolled commands are provided or there is a misconfiguration.
The provided MBS navigation package allows for point to point navigation
utilizing GPS coordinates or indoor map coordinates. It integrates the MoveBase package which in
turn allows for collision avoidance. This package is currently designed
for 2D planes with a planned expansion for 3D planes. Caution must be
exercised when using the package around people and or in an
un-constrained environment as any fault in sensors or misconfiguration
may lead to an accident.
Configuration
In the provided package, several configuration have to be adjusted which
are:
Localization
GPS localization config file
Odom localization config file
MoveBase
Base local planner params
Costmap common params
Global costmap params
Local costmap params
Movebase params
In-depth information is documented by the authors of the robot
localization package.
GPS Localization Config
In this configuration file, we combine three sensor readings, which are
the robots odom, imu, and the gps.
frequency: 20
The frequency depicts the rate at which the node publishes
information.
two_d_mode: true
It tells to ignore the height readings from the incoming sensors
as we are navigating in 2D.
publish_tf: true
Publishes a transform from the map frame to the odom frame
transform_time_offset: 2
Offsets the transform as some packages require transforms to be
future off-set by a few seconds.
Setting the sequence of transforms for this localization node.
odom_frame: odom
base_link_frame: base_link
world_frame: map
map_frame: map
It is important to change the odom to the odom published by your robot.
odom0: /your_robot/odom
This is typically published by the robots controller
The boolean values are (X, Y, Z, roll, pitch, yaw, Xv, Yv, Zv,
rollv, pitchv, yawv, Xa, Ya, Za).
v is velocity and a is acceleration
odom1_differential: false
It is highly important to tune the process noises.
process_noise_covariance:
This determines on how much to trust the incoming data. Each line
represents X, Y, Z, roll, pitch, yaw, Xv, Yv, Zv, rollv, pitchv,
yawv, Xa, Ya, Za. Values for these are assigned along the
diagonals.
initial_estimate_covariance:
This determines on how much to trust the initial data. Each line
diagonals.
For more information, the following repository by MethylDragon has a
great explanatory guide.
Odom Localization Config
In this configuration file, we combine two sensor readings, which are
the robots odom, and imu.
frequency: 20
information.
two_d_mode: true
publish_tf: true
Publishes a transform from the odom frame to the map frame
transform_time_offset: 1
odom_frame: odom
world_frame: odom
It is important to note that the DWA planner is no longer used and we use the TEB planner.
Configuration for the teb planner can be found in the TEB planner wiki. An excellent resource
for tuning your TEB planner is vailable in TEB planner tuning.
It is recommended to configure the move base planner to ensure correct
movement. Several important ones are:
meter_scoring: true
When true distance is measured in meters.
yaw_goal_tolerance: 0.157
Tolerance in radians for movebase.
xy_goal_tolerance: 0.25
Tolerance in xy coordinates for movebase.
path_distance_bias: 0.35
Weighting factor of how close the robot should stay to the path.
goal_distance_bias: 1.0
Weighting factor of how close the robot should attempt to reach
the goal.
heading_lookahead: 0.325
Tolerance of looking ahead for available space for turning.
For more information, the following MoveBase Wiki has a brief
explanation.
Costmap Common Params
The costmap will be used to integrate and utilize your existing sensor
for collision avoidance.Important parameters for this are:
The footprint defines a square size for the robot. The robots mid
point is taken as 0,0 and the the corner points are the distance
from the mid point.
footprint_padding: 0.1
Safety-gap that inflates the original footprint.
obstacle_layer:
Sensors that are utilized for sensing. Typically, scan is used
for LiDARs and the sort. Important is to change the sensor_frame
to match the URDF and the topic to match the input message of the
LiDAR.
For more information, the following Costmap Wiki has a brief
explanation.
Global Costmap Params
The global costmap of movebase node, as the name states publishes the
global costmap. It takes the map, provided by the map server as a static
layer. An important point to note is that some warning messages may
occur if the on board computer system do not compute the transforms fast
enough. These warnings can be ignored.
Local Costmap Params
The local costmap of movebase node publishes the local costmap. It
ypically requires the odom frame to operate. However, as we want to
depend solely on our GPS, we utilize the map frame for the local costmap
as well.
MoveBase Params
The movebase params are important for changing the planner frequency and
controller frequency. Usually the default settings are sufficient.
recovery_behavior_enabled: false
It rotates the robot to recover from faulty planning failures or
positioning, at times this is not desirable and may need to be
turned off.
Simulation Navigation
The first step is to begin the simulation and the navigation stack
via:
The second step is to ensure that both the MBS ROVO2 are in the
same location on the map and in Gazebo. If the position is different,
then on the Tool bar of rviz, select the 2Dposeestimate and
correct the position so that it closely matches the position in the
simulator, the ‘Adaptive Monte Carlo Localization (AMCL) should
correct the position of the robot as it moves around on the map.
Next, select the 2DNavGoal; then select a position in the map
within the white space, click and drag towards the direction in which
you want to robot to move to.
The robot should begin path planning and move both in the simulator and in rviz. The movement may not match if the simulator is not
powerful enough.
Real-world Navigation
The first step is to begin ROS cores and the navigation stack via:
The second step is to ensure that both the Rovo are in the
same location on the map and in the real world. If the position is
different, then on the Tool bar of rviz, select the
2Dposeestimate and correct the position so that it closely
matches the position in the simulator, the ‘Adaptive Monte Carlo
Localization’ (AMCL) should correct the position of the robot as it
Rovo Mapping
Simulation Mapping
A sensor device is required with the Rovo for mapping such as a depth camera or a lidar.
For autonomous navigation, the first step is to build a map of the environment. The map can be built either for a virtual environment or the real environment. For mapping, the first step is to load up
the simulation and the pre-configured Rviz file.
roslaunchrovo_gazebogazebo_world.launch
The next step is to open a new terminal and start the gmapping tool
via:
roslaunchrovo_navigationmap_navigation.launch
The next step is to begin mapping, this is done by either moving the
robot using the remote control or via teleop:
Once the entire region is mapped, you can save the map via the
following command:
rosrunmap_servermap_saver-frovo_map
You will get two files in the directory from which you run the
map_saver command; first is rovo_map.pgm and second is
rovo_map.yaml. Place these maps inside of
rovo_navigation/maps.
Next navigate towards
rovo_navigation/launch/rovo_navigation_stack.launch and replace
the room_map.yaml with the updated map, in this case rovo_map.
Real-world Mapping
Steps 2-6 for setting up the map environment for the real-environment
is identical. Only in step 1, you must run this command instead of
the previous one:
rosrungmappingslam_gmappingscan:=base_scan
Rovo Localization
Once the mapping is set up, the ROS navigation stack can be verified.
For this, first, run:
Next run:
At this point, the rovo, particle cloud, map should be visible,
meaning that the navigation stack is working, for controlling the
robot, you can view it in the RovoControls section.
