Operation
To operate the robot remotely via PC, you need to setup your network as described in the Rovo Network section.
Important
Please note that some Rovo may not have the latest drivers and have the old structure layout. In those cases where the instrcutions are not clear please contact support@mybotshop.de.
Real-Rovo
To start the real-rovo drivers, please launch:
ROS-NOETIC
roslaunch rovo_bringup system_bringup.launch
ROS-FOXY
ros2 launch rovo_bringup bringup.launch.py
Warning
Non-technical persons are not permitted to use the device as the damage it can cause is catastrophic.
Simulated-Rovo
To start the simulated drivers, please launch:
ROS-NOETIC
roslaunch rovo_simulator gazebo_world.launch
Visualize-Rovo
To view rovo current state, please launch:
ROS-NOETIC
roslaunch rovo_viz view_robot.launch
ROS-FOXY
ros2 launch rovo_viz view_robot.launch.py
Rovo Teleop
Important
The Rovo has to be switched to gear before control, to switch the gear please see Rovo Control.
To operate the Rovo either in simulation or the real robot, the following command may be used:
ROS-NOETIC
rosrun teleop_twist_keyboard teleop_twist_keyboard.py
ROS-FOXY
ros2 run teleop_twist_keyboard teleop_twist_keyboard
Warning
Please ensure the vicinity near the Rovo is clear when operational as it can cause severe damage.
